Extract data from XY graph
Hi mahesh,
next time you should set some typical data as default for the graph…
Right now you use the X-position of each cursor directly to index the data arrays, but that's wrong! The x value isn't the index! You have to filter both arrays (X and Y) to allow only points with X value in specified range…
Are your points stored with increasing X value? Or do you measure them in random order?
Message 11 of 17
(1,962 Views)
hello,
Please how can i extract data from a graph XY?
I want to calculate the variance/average of the amplitude (Y)
thanks
Message 12 of 17
(1,855 Views)
Hi smourad,
quick&dirty: use a local variable of the graph.
General answer: by using dataflow you don't need to read from the graph! You already have the data available in the wire feeding the graph!
Message 13 of 17
(1,839 Views)
Message 14 of 17
(1,773 Views)
I am an absolute LabVIEW novice and am struggling with some legacy LabVIEW 6 (2001) code which collects and plots 3 types of data on a 3-line XY multiplot, but crashes before the data is written to an output file. I would like to extract data from the multiplot, and followed this method under "In LabVIEW 2009 and earlier" to copy the graph to a new VI, turn it into a control, and wire it to the 'Write to Spreadsheet File VI' which I did with the wire tool that appears with the spacebar. Unfortunately the resulting wire appears as a dashed line with an error window: "You have connected two terminals of different types. The type of the source is 1-D array of cluster of 2 elements. The type of the sink is 1-D array of single." I am happy with any type of output file (csv, binary, etc), but would like advice on how to convert between the types and wire it to an output.
Message 15 of 17
(1,770 Views)
Hi KEA,
why don't you attach your VI (or atleast the relevant parts)?
Message 16 of 17
(1,759 Views)
The attached vi contains the multiline graph that I am trying to wire a file output to.
Message 17 of 17
(1,754 Views)
