Extract blocks strings of length 4 into array
I am attempting to place a string into an array.  However, the length of the strings should be 4.
If my input is ABCD0122FFEA the output array should be
ABCD
0122
FFEA
Thanks!
(1,468 Views)
ABCD
0122
FFEA
Thanks!
Your code is more complicated than it needs to be (besides not working correctly).  Think about your requirement.  Isn't this really about ripping the first four characters out of your string, placing it into an element, then repeating this until you have no more characters left?
HINT: Look in Additonal String Functions to see if you can find anything useful there.
Note:
If this was a message that needed to be decoded as three chunks of data, I might approach this differently.
Bill
CLD
(Mid-Level minion.)
(1,465 Views)
You were actually pretty close.  I removed the initial String Subset that was outside of the loop and then got rid of the Shift Register.  A little more cleaning up and this was my result.
(1,409 Views)
  • Is the string length guaranteed to be divisible by four? Is it always 12? Can the size be very large?
  • What should happen if the size is not divisible by four (truncate? Pad with special character? Last element has less than 4 characters?)
  • Why did you not wire the substring length?
  • Why do you also take a substring before the loop?
  • What's the purpose of the indicator named "substring"?
  • Why do you think you need a shift register?
(can be simplified depending on how much is known about the input, see above)
(1,403 Views)
