Extract 2D array element
Hi guys assuming I have a 2D array with 3 element.
e.g 280 400 784
How do I extact element 0 and 1 separately.
(4,845 Views)
Hi Nextal,
your example describes a 1D array...
(4,842 Views)
Hi GerW,
Sorry, I only type out a row.
It should be like this:
e.g:
280 400 784
270 450 744
299 401 755
If I only want row 1 element 0 and element 1. How should I do that?
(4,836 Views)
Hi Nextal,
either:
- index row 1, then index the elements from the resulting 1D array
- wire both indices to get the needed elements
(4,832 Views)
To expand on Gerd's response, when you wire a 2D array to the array index primitive, there will be more terminals available for you to select the row and/or column index.
(4,812 Views)
