Extra space in window title bar
I'm using LV 2018, 32bit on W10, 64bit. I have an app which, when I run it, shows an extra amount of white space above the above the main LV panel, right below the windows title bar. See the screen shot: the Title bar says "MIP Mainten...", and then theres several dozen white pixels vertically before the menu bar. Oddly, if I turn off "Centered" for Run Time WIndow Position, and use "Unchanged", this goes away.
I'll add the "Center" method to get what I need, but any idea why this is happening, or if it is worth reporting as a bug?
    DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
(2,504 Views)
I have a slight memory of reading about this some 10 years ago. It only happened on certain graphics cards, and not all of those cards, so it was a driver issue.
What card and driver are you running?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,446 Views)
Is the resize disable in VI properties?
George Zou
(2,399 Views)
