External Trigger: Reference or Start
I'm trying to do DAQmx for a shaft encoder, and would like to see my data at specific points of the the shaft rotation (say at 3 quarters of each rotation) .
1) What trigger should I use (appears when clicking on trigger option in DAQ Express): Start or Reference?.
2) The shaft runs @ max frequency of 50 Hz. What will the suggested number of samples will be if I need the results for a few seconds?
I'm using:
LabVIEW 7.1
PCI 60 24 e
BNC 2090
Many Thanks..
Mohamad
(3,369 Views)
If you want to see the results at 3/4 I suggest the sample rate be more than 8 (nyquist limit, 2 x 4) * 50 (50 hz)  Then multiply the sample rate * number of seconds you want to view. Obviously the higher smaple rate, the more accurate you can get to the 3/4 rotation location.
I use reference for my trigger.
(3,367 Views)
Hi Joseph Loo ,
Many Thanks for your message... I'll try that
(3,337 Views)
