03-07-2006 01:40 PM
03-07-2006 03:44 PM - edited 03-07-2006 03:44 PM
Attached is what I have so far...can I get some feedback/suggestions on how to improve this thing?
I have not had a chance to try the EXTERNAL portion of the program...can anyone tell me if I coded this correctly?
Message Edited by esa_paranoid on 03-07-2006 03:44 PM
03-08-2006 09:53 AM
03-08-2006 03:37 PM
03-08-2006
03:53 PM
- last edited on
06-03-2025
08:30 AM
by
Content Cleaner
03-08-2006 05:07 PM
08-11-2006 08:12 AM
03-03-2010 07:15 PM
Hi, I am calibrating a SXCI 1102 with calibration executive version 3.3.1 using a PCI 6030E daq device, a fluke 5700A calibrator and a agilent 34401A DMM. The 1102 is new just out of the box and a few days ago other 1102's were calibrated successfully with the same setup. All equipment used for this calibration just got back from getting calibrated themselves. During the calibration a few channels fail calibration on the 1102 so I suppress alerts for the test and it them finishes the verification them proceeds to the adjustment phase. During the adjustment phase I get the following error message:
Error-200546 occured at DAQ MX close external calibration .vi at step adjust:1
physical channel name: SC1Mod2/ai0
Possible reason(s):
Measurements: External calibration failed, and the external calibration data has not been changed.
Make sure that the reference signal used for the calibration is stable and that the voltage mataches the value specified to the calibration software. Disconnect the device from any external signals that might introduce noise.
Any thoughts?
03-05-2010 05:48 AM
Hi Titan666
Yes, I experiences the same problem, especially with M Devices. It is more than likely an electronic noise problem. Ensure you use low noise, well grounded, gaurded signals from the DC reference. You might have to experiment a bit. I had to use different connections for the NI 6110 and my NI M device.
CSV
