01-02-2007 01:23 PM
01-02-2007 02:02 PM
The most likely reason I could think of for this error is that your top-level Config Page VI is broken. If you open the config page VI, is it runable? I assume you are using the Express VI Development Toolkit? What happens if you create a new blank Express VI? If that one doesn't give you the error, you might start comparing between yours and what you start with to see if you can isolate what is different about yours such that the error occurs.
Good luck!
01-02-2007 02:28 PM
01-02-2007 03:41 PM
01-02-2007 03:59 PM
01-03-2007 11:09 AM
01-03-2007 11:21 AM
