Exporting variables -- data columns not consistent
I am using the export variables function to export several .lvlib files to .csv format.  The strange thing is, the data columns that are exported are not consistent from one file to the next.  For example, in one .csv file I see columns for Logging, Logging:LogData, and Logging:LogEvents, and in another.csv file these columns are left out completely.  Is this a bug or by design?
(2,871 Views)
Hello, are you exporting from Measurement and Automation explorer? Could you post an example of this column problem? Which version of LabVIEW are you working with?
(2,844 Views)
Hi Anna,
Thank you for your reply.
I am exporting from LabView8.5.  I right click on the .lvlib file, and select Export Variables.
I have attached 2 .csv files.  ExportToCSV1.csv contains 26 columns.  ExportToCSV2.csv contains 23 columns.   The 3 columns that are unqiue ExportToCSV1.csv are "Logging", "Logging:LogData", and "Logging:LogEvents" in columns P, Q, and R.
(2,824 Views)
