Exporting data from NI MAX to excel
I am measure 72 different voltage signals with the USB-6255 multifunction I/O device and NI MAX
at the same time (please look at the pictures).
Now I am trying to export these data into one excel sheet, but I have only found the option to get the data from one signal of the first 15 signals in one excel sheet, which you can see on the right side of the diagram.
I haven´t found an option to get the data form signal 16 - 72.
Is there an option in NI MAX to do it, which i haven´t found yet or do I need a Labview project for that? How would the project look like? (I have never worked with Labview before)
Thanks for any help!
(2,634 Views)
Accepted by topic author kammer@pi-berlin.com
Hi kammer,
I guess you are using testpanels in MAX to read those signals: they are just "test" panels, not intended for "productive work"…
Start LabVIEW, do some basic training as offered at the top of the LabVIEW board.
Then open the example finder within LabVIEW, navigate to the DAQmx example VIs and examine the more simple "acquire voltage signals" examples!
(2,593 Views)
Thanks for the help!
Best regards
Kammer
(2,554 Views)
