Exporting VI content (objects and connections)
Hello everyone,
I would like to obtain a list of the objects AND connections of the block diagram of a VI. In other words, I would like to find out from a VI what objects, subVIs etc. contains an other VI...  Is this possible somehow?
(e.g. if we have two boolean controls, named Bool1 and Bool2, a boolean indicator, named Bool3, and these three are connected by the means of an AND gate - Bool3=Bool1*Bool2,
then I would like to obtain the content of my VI, which is either the formula Bool3=Bool1*Bool2,  or something like a date packet
Controls: Bool1, Bool2;
Indicators: Bool3;
Objects: AND gate;
Connections: Bool1-1st input of AND gate, Bool2-2nd input of AND gate, Bool3-output of AND gate).
The Export Strings function from the Tools menu exports only a tagged list about the objects, without mentioning anything about the connections.
Hope you understand my question!
Thanks a lot for your help!
Lorant
(3,440 Views)
Hi Lorant,
I am not sure of that point but I don't think you can get a list of the variables declared in a VI.
About the second point I doubt even more.. I would be very very surprised if a function can tell you how the variables are linked inside of a VI...
Sorry...
Epictetus
Antoine Chalons
(3,427 Views)
It almost sounds like you're trying to perform the old "text-style" documentation of a LabVIEW program. Also known as "can I generate C-code equivalent of my LabVIEW code?". Is this for documentation purposes?
(3,408 Views)
Hy,
no, it's actually not for documentation purposes, but does it matter...? I've found a good way of evaluating such a content of a diagram, but in Simulink. The Simulink saves the model in an .mdl file, where such a list about the object and connections exist, so it seems reasonable to create the model in Simulink, and the evaluation of it in LabVIEW....
(3,398 Views)
There is just one point I'm just thinking about that... for instance when you have a multiplication, if you right click on the output part and choose "create indicator", an indicator is create with a default name "X*Y"... that sort of mean that LabVIEW can, in some cases, tell you where the outputs come from, no ?
Epictetus
Antoine Chalons
(3,394 Views)
I think there MIGHT be a chance that this is possible using LV scripting.
Try searching the LAVA user goup forums for scripting.  If I remember correctly, I think they were able to access "Wire" objects (with names etc.)
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,392 Views)
You can also view the VI hierarchy. This will show a tree of all of its subVIs and custom controls (anything saved as .ctl). It doesn't give any information about the logic involved in the VI.
Select the menu item Browse >> VI Hierarchy (LabVIEW 7.1 and before) or View >> VI Hierarchy (LabVIEW 8.0) to see this information.
Jarrod S.
(3,372 Views)
