Exporting Labview Code in readable format
Hi.. I got stuck in a serious problem, need help. Can I get any suggestion about how to read/export/transform labview VI into readable format.
Message 1 of 11
(6,859 Views)
Hi Sarah,
Print the front panel and/or block diagram: Edit->Print…
Message 2 of 11
(6,849 Views)
Hi.. How can i get the Labview code in the DFIR format ?
Message 3 of 11
(6,845 Views)
Hi Sarah,
you cannot.
Please keep related questions in the same thread!
Message 4 of 11
(6,826 Views)
Besides, that would be anything but "readable" in relation to your original thread!
Rolf Kalbermatter  My Blog
Message 5 of 11
(6,773 Views)
Readable by humans or readable by LabVIEW? A simple VI can be read by LabVIEW and by any human that has LabVIEW installed. 😄
It would really help if you could add a few more sentences to explain the purpose of it all (e.g. archiving, documentation, patent application, documentation for the supervisor, etc. etc.).
Please note that translating LabVIEW code into any non-VI form will be lossy and basically irreversible. There are many thing that are not visible in pictures (mechanical actions of buttons, configurations of express VIs, execution settings, hierarchies, etc. etc.)
Message 6 of 11
(6,750 Views)
for example, UML model of any system can be easily exported in XMI/XML format and that XMI can be easily readable by code written in any other language (like java etc.). As, I am working with labview and I am interested in exporting VI in any other readable format but the only ways I have found are either .jpg or .dll file (but they are readable 😞 ). Can I export it in any other format?
or Can I get DFIR graph of corresponding VI from G compiler??
Message 7 of 11
(6,717 Views)
Hi Sarah,
Did you read message #4?
You forgot PDF as mentioned (or implied) in message #2.
LabVIEW also supports HTML, RTF and plain text documentation…
Message 8 of 11
(6,707 Views)
I want to get equivalent representation of VI in any other textual language
Message 9 of 11
(6,700 Views)
Hi Sarah,
Then you need to recreate (aka rewrite) the algorithm used for your VI in that other "textual language"…
Message 10 of 11
(6,679 Views)
