Exporting Data to Excel
Hi Jon,
here's a picture (of your vi, containing some Rube-Goldberg code) to illustrate Raven's answer... Please give us the correct vi!
Why not change your sampling schem from "10 samples 1000 times a second" to "10000 samples once a second"?
Do you really think the DAQ assistent needs only 1ms to perform all tasks needed? The assistent has to: open & initialize the DAQ device, read the samples, cleanup & close the device! The express vis are nice, but not very fast (and need a lot of memory too...). It's (mostly) always better to do the same using low(er) level functions...
Message Edited by GerdW on 03-27-2008 09:17 AM
Message 11 of 17
(1,777 Views)
I told you it had been a long day... Smiley Sad A case of doing lots of modifications without saving them!
I have attached the latest VI where I have changed your cleaned up VI to include how I was trying to write the data to the spreadsheet. This is only one out of three ways I've tried (though none seem to work!)
So using the lower level VI's, is there a tutorial for these? I might have a play in a minute!
Any changes you can see would be a great help!
Jon
Message 12 of 17
(1,758 Views)
Hi Jon,
you should append to the file, when you need all values...Smiley Very Happy There's an additional input at the file-write!
You should also use "Build path" and utilize "Format into String" more extensively.
Message 13 of 17
(1,744 Views)
Sorry I am still confused, I have looked over your VI (and thanks for the improvements) but can't see a change to the fundamental issue of the data loss/writing? I see you have changed it to append to new file (or the other way round) however I am still only getting roughly fifty results through to the spreadsheet? Where am I going wrong? Hopefully its something simple?
Jon
Message 14 of 17
(1,737 Views)
Hi Jon,
I have stripped the attachment to show only the relevant part: generating dummy data and saving to text file...
For me the data is appended to the file, quickly generating a lot of values...
When this runs fine for you too, then the DAQ part has problems:
It seems you don't get as many readings as you think you should. Use the highlight tool and some probes to check this
Message 15 of 17
(1,728 Views)
Hello, I'm having a problem as well.
I'm using 2-NI9211, interfaced with 2-NI USB-9162 modules measuring 8 thermocouple temperatures.
But I've been trying for quite sometime to wrap my head around exporting the data to excel or at least storing it to a .csv file.
Could someone please help point me in the right direction? Thank you
Message 16 of 17
(1,622 Views)
Message 17 of 17
(1,618 Views)
