Export Simplified Image issue
Hi
I'd like to report a strange behavior of Export Simplified Image (ESI) on waveform graphs and charts. Provided that the graph has a white line on a black background, ESI exports always a graph with white background. The line is drawn in black, which is fine. However, if there are sample points drawn on the line, which are also originally white, they become white in the exported image, too. Thus, they are not visible, and they are even drawn over the underlying black line. I'm attaching a couple of images for demonstration.
Vladimir
View my profile on LinkedIn
(3,263 Views)
Thanks for letting us know!  I will look into this and file a corrective action request if necessary!
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(3,237 Views)
Are you using LabVIEW?  If so, what version are your finding this with?
Thanks!
Daniel Eaton
Systems Engineering
(3,236 Views)
    It's LV 8.2.1. Are you not able to reproduce the issue?
(3,222 Views)
I actually was able to reproduce it.  This was reported to R&D ( CAR#: 43KA46E9 ) and will be fixed in LabVIEW 8.5.  A possible workaround is changing the color of the plot to be something other than white. Thanks for the feedback!
Daniel Eaton
Systems Engineering
(3,208 Views)
