Export NI-DAQmx Configuration not working
I need my NI-DAQmx configuration to copy from one project to a new one. However, when I right-click my RT device>Export. Nothing happens.
PaulG.
Retired
Message 1 of 8
(3,415 Views)
Hi Paul,
When you say nothing happens, do you mean that the Export option is grayed out and/or the wizard isn't running, or are you not able to find the configuration file once wizard has run?
Message 2 of 8
(3,387 Views)
Nothing happens after I select export. Can't import either. This is in V2012 BTW. I'm going back to V2011, at least on this system. I'll get back later with details if this fixes my problem.
PaulG.
Retired
Message 3 of 8
(3,376 Views)
Back to square one. Smiley Indifferent Everything in the two machines is identical: Hardware, software, etc. I cannot import or edit DAQmx channels in my RT system. The other system works fine.
PaulG.
Retired
Message 4 of 8
(3,356 Views)
I take it you are attempting to export these settings through MAX? Could you check which version of MAX is running on each machine?
Message 5 of 8
(3,330 Views)
The working machine is using MAX 5.0. The non-working machine is using 5.3
PaulG.
Retired
Message 6 of 8
(3,319 Views)
Hi Paul,
Could you generate and post a MAX Technical Report for each of your systems? These reports will help us determine exactly what is different between the two systems.
Instructions on generating the report can be found at the link below:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Message 7 of 8
(3,285 Views)
This is taking way too long. Smiley Indifferent One-per-day emails from NI support ask me for screen shots of software wizards. Smiley Indifferent We are going to try building the next test panel. It's identical to this one that is giving us trouble.
PaulG.
Retired
Message 8 of 8
(3,275 Views)
