Explain error code 63
I am trying to control equipment via ethernet and somtimes get the error message "serial port receive buffer overflow". This stops the VI running. Could you please explain what this means.
(3,139 Views)
Charlie,
the error explanation for error 63 also says "LabVIEW:  The network connection was refused by the server.". Investigate into this error message. I guess that your LabVIEW application (TCP/IP function), for whatever reason, looses the connection to the server while you are communicating. The problem could also occur, when the server you're connected too stops working.
Hope this helps!
Cheers, Stefan
Impossible is nothing - nothing is impossible
(3,119 Views)
