Experiences with NI USB-6008 / 6009?
I am a student of mechatronics and currently pondering whether to buy
the NI USB-6008 / 6009 and now seeking information about it.
Perhaps someone here in the newsgroup has already made experiences with
this device. If yes, would you recommend the USB-6008(9)? Or otherwise,
why not?
Matthias
(2,447 Views)
I have used both devices and think that they 'Do exactly what it says on the tin'.....
P.S. I have been using and buying Labview for a number of years now.... So I guess I knew what to expect.
I suggest you search the forum for others problems, they seem to come down to not understanding the specifications clearly. Or understanding how to match specifications to hardware. i.e.The counters capability on the higher spec. model or the analog output. Or the overall analogue throughput.
It's a low cost device but I think it fills its place well. Strongly recommend the prototyping areas as well as you will probably neeed some conditioning circuitry due to the cost effective analogue input ranges.
What is the project...?
(2,441 Views)
