Exit from the application using event structures
Hi
In my project i used event structure it working fine.
Now i want to exit(close) the application when i press EXIT button on the front panel.
Here i attached my project give an idea.
Regards
hari
Message 1 of 11
(4,270 Views)
you can use the Exit or Stop functions available in the application palette... Exit will close the LabVEIW window and Stop will stop you code.. Create an event and place the function inside that...
24358i841BFF08690AB10D
Message 2 of 11
(4,255 Views)
I have seen your code. It's Ok
You can stop the program in the same manner...
But if you want to completly close Labview, you can use.
Application Control --> quit Labview.
but it is not recommended. Otherwise you can use stop in the same menu...(to stop the VI).
Step out of your comfort zone to experience the real you!
Message 3 of 11
(4,249 Views)
Hi SAM
U saw my ok.i have one more problem when i run the program(main vi) all the remain sub vi's also opened.
i want open sub vi when i press a button on front panel.
i have made small changes to it.
Regards
hari
Message 4 of 11
(4,239 Views)
Accepted by topic author thinnker
Hi thinnker,
    You have to change the Sub VI node setup to do that... Do that then it will open whenever you call it..
24368iEF81720536A2430F
Smiley Wink
Message 5 of 11
(4,218 Views)
Br.anand has the right idea. The same effect can be achieved by using the VI Properties dialog and setting the Window Appearance settings. Br.anand shows how to change the window behavior for one call to your subVI. Use the VI Properties to set the behavior for all calls to that subVI.
Message 6 of 11
(4,192 Views)
Also review this nugget by Darren
Felix
Message 7 of 11
(4,139 Views)
Hi
I want to assign a character(key board keys) to buttons in an event structure.
I don't want mouse for the participation u tell me an idea.
Regards
hari
Message 8 of 11
(4,080 Views)
Select the control which you want to control by using keyboard. right click >> properties>>Key navigation then assign the key you want ot use.
Smiley Wink
Message 9 of 11
(4,075 Views)
hi anand
it working with special function keys.
i want it alphabets,is it possiable.
Message 10 of 11
(4,064 Views)
