Exit a for loop
I need to use a for loop in my VI; but I need a way to exit the for loop when I hit the stop button. I found that you can add a conditional terminal to a for loop in Labview 8.5; but is there a way to do this in Labview 8.0?
Message 1 of 11
(5,927 Views)
No. You cannot exit a for-loop in LV prior to 8.5. Smiley Sad
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 11
(5,921 Views)
So...can anything be done to get around this?  The entire for loop takes approx. 1 minute to set the voltage on a certain device, measure some input, and then collect data from other sources (using a DAQ to do the collecting). I need to find a method to hit a "stop" button and have the program go back to  a state where it sets all the ouput voltages back to zero.  However, if I hit just hit a terminate button, the program quits where it is at and the voltages that are being sent out of the DAQ do not go back to zero.  Any suggestions?
Message 3 of 11
(5,908 Views)
Hi JoshRMPS,
why don´t you use a while loop?
Mike
Message 4 of 11
(5,906 Views)
I wish I could...but I need to take advantage of the iteration terminal that a for loop offers to run my structures.
Message 5 of 11
(5,903 Views)
Hi JoshRMPS,
can you show your vi? I think there is a solution with a while loop. Smiley Happy
Mike
Message 6 of 11
(5,896 Views)
I have attached an image file of my VI.  Note that there are quite a few structures involved in the program and I am trying to find a method to get out of the for loop at any point.  Thanks.
Message 7 of 11
(5,894 Views)
Hi JoshRMPS,
see the attached picutre, if i understand you right, then this should also work for you.
Mike
Message 8 of 11
(5,890 Views)
I think this might work.  I will have to give this a shot and see how it works.  Thanks so much.  I will let you know how it works...but I might not get be able to get back to you until tomorrow.  Thanks.
Josh
Message 9 of 11
(5,879 Views)
Looking at your VI, I think exiting the loop is the least of your problems. This VI needs to be redesigned from the ground up as one simple state machine in a single loop that fits on one screen size. Now all you need to do is switch to a special case if need arises. Instead of exiting a FOR loop prematurely, the problem is reduced to switching to a different state in a state machine.
With the current design, you are really painting yourself into a corner. You first need to fix the very fundamental design flaws of your code.
Currently, your VI is a loose collection of isolated statements, many without any defined execution order. What makes you think that the stuff outside on the left will execute before the sequences on the right? How do you guarantee that the various "smart buffers" get emptied before the first value gets entered into them? What's up with the big case structure? Are you running this in "continuous run" mode??? All your "smart buffers" could be replaced with plain shift registers!
Message 10 of 11
(5,844 Views)
