I'm a LabVIEW developer who is currently wrestling with Signal Express. I have a user who wanted a general purpose data logging software application written, then we saw Signal Express and thought 'That looks like what we need'. As he is short of budget and I am short of time we are giving it a go.
I struggled to get to grips with the basic idea of dropping the steps into the area on the left. I thought they executed in order, but that's not so. They seem to run as seperate parallel loops, unless one specifically requires an input that is the output of another.
What I would like to do is have a step that only runs once - say at the beginning or the end of a logging session. One instance would be to set an analog output to a level it was needed at for a complete session, and then to ensure it's set back to 0V when the session is ended.
Another would be to call a LabVIEW.vi once at the begining to set up a serial port. After polling the serial port for data regularly throughout the logging session using a second vi I'd then like to shut it down at the end with a third. All the serial port stuff has to be done in LabVIEW .vi's as Signal Express itself doesn't deal with the serial port. (If Signal Express can do this please point it out to me, as I've missed it).
I hope this is clear enough, but if not let me know and I'll try and clarify what I'm looking for.
Bandit.
