Executable
i did a data basis in ACCESS together with Labview, but when i do an executable it's not possible to catch the values from data basis. only with the executable the access don't talk with the program (Labview-exe).
(3,930 Views)
What exactly happens when you try to talk to the Access database from your application? Are you getting an error? How are you making the connection between Access and LabVIEW?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,930 Views)
Mike,
what i'm realizing is that i have labview version 6.02 and my application builder is version 6.0, which seems not to have some vi's of report generation and them i can't creat an executable or when create it doesn't work. problem with access is solved when i installed sql server in the machine which i'm runing my executable, but now i can't open excell file because of this version problem. i tried to save with option to labview 6.0, but this specific vi was not saved. what i can do?
regards,
marcio
(3,930 Views)
There is an upgrade available for the app builder. You can download it from the same place that you downloaded to 6.0.2 updater.
Mike...
LabVIEW Champion
(3,930 Views)
Mike,
we bought a professional license together with an application builder. problem is that at this time, last version of labview was 6.02 and for application builder was only 6.0. i received this package together. now i need to have this upgrade for application builder, but i don't know how or where i can have it. i needed to have this as soon as possible and for free if it's possible. can you help me?
(3,930 Views)
To do a complete 6.0.2 update, you need to run the updater, then replace the lvrt.msi file in the LabVIEW6/AppLibs/Installs directory with the new one that comes with the updater.
Mike...
LabVIEW Champion
(3,930 Views)
