Executable works even if I didn't include all the vis
Hi everybody,
I'm facing a weird behaviour building my executable from LabVIEW: I've just realised now I forgot to include some essential VIs in my executable (in the Build Specification properties - Source Files tab). Despite of that, launching the .exe (from my PC where LabVIEW developing environment is installed) I have no problem in getting it to work perfectly!
Possible explanation: in some way missing VIs get called from the executable????
Does someone have a better explanation?
Many Thanks.
(3,183 Views)
All subVIs in the hierarchy of the startup VI are included automatically. How are you calling the subVIs?
(3,178 Views)
I see...
Actually I'm quite new to LabVIEW, been working and playing with it for a couple of month.
So I don't need to put all my VIs in the "Always included" folder, I suppose.
I imagined there should be a simple explanation.
Thanks a lot.
(3,175 Views)
The simple explanation is this: If you are calling the subVI's by reference through the VI server they are not considered a "dependency" and therefore are not automatically included in the build of an exe. This is when you would need to place those VIs in "Always Included." When you place a subVI dirtectly on the block diagram then it is included in the dependencies and will be automatically built with the exe.
(3,137 Views)
Most often, you should always assume that LabVIEW is smart enough to do everything it possibly can automatically. 🙂
(3,126 Views)
