08-02-2019 07:25 AM
Hello Team, I am building an application using ‘TrioPC’ active controller to connect to Trio Motion Controller. I have created an executable using application builder and trying to run it on another application where I have installed the setup which was build through ‘Application Builder’.
Issue – Exe does open but connection does not gets open and does not read values from Trio Controller on new machine. But when I run same exe in my machine (on which i have developer edition is installed), it opens up the connection and retrieves the data from controller. Executable runs successfully on my machine but not on different machine.
Please help me guide if I am missing anything while building executable. Or anything else I need to take care of. LV version I am using is – LV17.
Solved! Go to Solution.
08-02-2019 07:42 AM - edited 08-02-2019 07:43 AM
08-02-2019 07:51 AM
Sure GerdW, will take care next time.
I don't get any errors, exe gets opened normally but connection to TrioPC does not open up. And hence it does not fetch values from controller.
Outer case structure is just to open the connection one time when exe is ran. And then use this connection in while loop for processing.
08-02-2019 08:02 AM
Hi fagcontrols,
Do you get any errors in the error wire in this case? Do you check the error wire somewhere? (Do you do some error handling at all?)
Still no reason for that structure…
08-10-2019 12:36 AM
There is one setup from Trio Controller (TrioPCMotion_2_20_2-A(x86)_Setup) which was missing on target computer. After installation of this setup I am able to fetch the data.
