Executable will only run with non reference thumb drive inserted - Get cFP read error if not installed
I generated an executable / installer for a customer that monitors thermal sensors via a cFP-1808. The exe works fine on my laptop (development machine). When I take the installer to either of my 2 deployment machines the VI works perfectly as long as the following 2 factors are true: My usb thumbdrive has to be present and it has to contain a specific .iak file... If the drive is inserted, but the file is not present, I still get the FP Read Error (specified tag name not found).
There is no reference whatsoever to the .iak file in question, anywhere in my code. I have gone to the destination machines, opened MAX and the correct .iak file for my program, setting it as default. I have verified that the FP Read sub VI is pointing to the correct .iak file as a default. I have built the installer and exe about 6 different times with different settings to no avail.
Has anyone seen this before?
Chris
One should welcome adversity as an opportunity to excel.
(3,042 Views)
I went through iak hell a few months ago building an exe. Loading the latest Fieldpoint drivers and including the iak file in my project as a support file (LV8.5) seemed to help.
Wish I could offer more specifics but I went through so many iterations/combinations of things I ended up with no firm path as to how it was finally resolved.
-AK2DM
(3,035 Views)
Analog,
I forgot to mention that, thanks for bringing that up. I uninstalled all NI software from the target machine and included the drivers in my installer, thinking the same thing.
Thanks.
(3,029 Views)
Daddy-O
What I meant was I downloaded and installed the lastest FieldPoint drivers from NI's site (v6.03) and installed them on my development machine.
Did you also try including your iak file as part of your development project? (Projects are new in LabVIEW 8.x)
-AK2DM
(3,010 Views)
