Executable menus corrupt
When I build an executable the menus and dialogs are corrupt. Both on LV2025 and 2026.
If I set only French or German in the language option when building it is ok.
I have Swedish and English (USA) on my PC.
I have searched, but not found a soultion for this behaviour.
/Staffan Ekstrom
(128 Views)
I'm looking at your picture. Specifically at the icon Top-Left. Which version of LabVIEW are you using?
"Should be" isn't "Is" -Jay
(86 Views)
2025 and 2026. Same on both.
/Staffan
(74 Views)
/Staffan Ekstrom
It looks like the wrong code page is being used for display. This may look strange if you are using Swedish. Anyway, the very first thing I would suggest checking is this:
LabVIEW is not fully Unicode-aware, so try setting the language to English here. Also, make sure you don’t have Swedish letters like “Å” in your menus for the moment. But in theory it should work if you will set Swedish for non-Unicode programs as well. Don't forget to restart after this change.
(35 Views)
ÅÄÖ isn't a problem. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(24 Views)
