Executable looking sloppy on the small window size? How to fix this issue
The front panel looks good on my big laptop as shown below. However, I tried creating an executable to use it on the small laptop, the executable does not look good at all. How do I fix this issue?
On my big laptop:
On the small laptop:
My configuration:
As you can see below, things don't look right.
When I tried to follow this link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kHoKSAU&l=en-US
I get this on the small laptop. As you can see, I can't see everything on one screen though everything looks good now.  I have to scroll left or right
My configuration:
How
(2,061 Views)
Now you get to understand what all you need to consider while developing an application.
By any chance, did you enable scale with pane for the controls? I would disable them, so that the scrollbars popup leaving the controls at same size irrespective of the monitor.
To develop a proper application that works with a variety of monitor sizes, you need to implement quite chunk of pane resizing, and control resizing in the code to work around the weird scaling issues.
Santhosh
Soliton Technologies
(2,052 Views)
Scale with pane is  disabled for all controls and indicators
(2,032 Views)
Looks like you have modified/customized the UI without considering the implication of each decision it would result in a smaller monitor.
In the current state, I would recommend starting from scratch and for each implementation consider how it would show up in a small monitor.
Could you please share the VI?
Santhosh
(2,026 Views)
Could your problem be a font size change?
I ran into this problem in the past when compiled LabVIEW front panels changed font size.
There were some *.ini settings for the compiled code that fixed it for me.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000fynASAQ&l=en-US
(2,020 Views)
I think also if the scaling on the two different computers are different, you may run into issues like this.
Bill
CLD
(Mid-Level minion.)
(1,969 Views)
It mainly (or atleast for starters) look like a font scaling issue. Change the windows font scaling or add the appropriate keys to the applications ini.
Stuff like
appfont = Tahoma 9 (assuming it'll scale up)
Qestit Systems
Certified-LabVIEW-Developer
(1,952 Views)
