Executable flashes at startup if the top-level VI is in a library
I noticed, when one of my LabVIEW executable starts, the front panel of the top-level VI always flashes briefly from its "development look" to its "runtime look", as if it was opened before the LabVIEW runtime starts.
Front panel of the top-level VI in development:
Window Appearance config:
Window Run-Time Position Config:
When starting the executable, the front panel always flashes like that:
My application is only 1MB, so it should load quickly.
I've tried all sorts of hacks, like:
 - checking "Window runs transparently" with transparency to 100%.
 - setting the runtime position to "Minimized" (with "Allow user to minimize window" checked).
 - adding "HideRootWindow=True" to the executable ini.
Anything I've tried, there was always some kind of ugly flashing...
...Then I dragged my top-level VI out of its owning library, recompiled and the issue disappeared completely!
So I wonder if it is a bug or if it is a somehow a performance issue due to the fact that the top-level VI forces the library to load before starting?
Attached is an example project to reproduce the issue.
Executable "Main in Library.exe" uses a Main VI from a dummy library > flashes at startup.
Executable "Main.exe" uses a similar Main VI that is NOT in a library > no flash at startup.
I could reproduce this behavior in LV2020-32bit (SP1) and LV2023-64bit (Q3) on Windows 10.
Raphaël.
(881 Views)
Thanks for the links.
Ah, too bad I didn't find your first linked thread before.
Anyway, the objective of my thread was more to point out a potential bug (which is apparently known since 2015).
As I understood, there seem to be a ton of workarounds (that may of may not work) but the root cause has still not been addressed/identified/corrected after many years...
Raphaël.
(725 Views)
