Executable files
Hi everyone
First sorry my english!
Well, I would like to open the notepad and then immediately open the edit option, all automatically.
But,  is it possible?
thank you
Message 1 of 9
(4,632 Views)
What do you mean by open the edit option - do you mean open the edit menu at the top? That isn't anything I've ever seen done before so I'm not sure if it's possible. Maybe you could simulate pressing the Alt+E keys to open the menu?
I had a quick google and it might be possible with calls to the Windows API (call library function node) - see here for details http://www.vbforums.com/showthread.php?345259-Use-API-to-programmatically-click-button-of-another-ap...
(blog)
Message 2 of 9
(4,625 Views)
I'm tempted to ask "Why do you want to do that?".  If what you want to do is to write a text file, LabVIEW can do that directly without using NotePad.
BS
Message 3 of 9
(4,619 Views)
I have a software that collects data from a multimeter (by Minipa)
need to run this software in conjunction with the labview.
But first, this software must be configured manually.
I would like the labview configuring it for me automatically.
Message 4 of 9
(4,611 Views)
That still does not make much sense. What is the relationship with Notepad and this other program? If this other program requires a text file, you can easily create/edit the file with LabVIEW. Opening Notepad would be manually changing the content.
Message 5 of 9
(4,603 Views)
I think he doesn't want to do anything with notepad, he uses it as an example.
He wants to change settings in Minipa menu, right?
If I'd be you, I'd simulate keyboard strokes https://decibel.ni.com/content/docs/DOC-9001
Message 6 of 9
(4,596 Views)
sorry but forget Notepad, Notepad will not be used
Message 7 of 9
(4,595 Views)
I would like the labview open the program and configure it to me
below and manual configuration
Message 8 of 9
(4,583 Views)
So why aren't you using the VISA serial functions to directly communicate to the instrument? You've selected a pretty indirect way.
In any case, you might also want to look at a program called AutoIT for controlling an external exe. It will even work with Notepad.;-)
Message 9 of 9
(4,577 Views)
