Executable doesn't run right on runtime machine
(2,719 Views)
More details forthcoming?wink smiley
(2,710 Views)
Hello Mc D,
Generally speaking, if you're VI works in the development environment, but not as an executable on a target machine, there are a few things you can check:
1. Did you install the LabVIEW runtime engine?
2. Did you install any drivers required by your application?
3. Do you have any file paths that are "hard-coded" in your block diagram?
More details would definitely help us sort out what could be going on. Thanks!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(2,690 Views)
