Executable crashes
I have an application that works great in development, but the executable crashes as soon as it is run.  There is nothing special going on in the application.  I am making calls to a dll that is in the Windows system directory, and am not using VISA or DAQ, or anything else.  Any ideas?
(3,631 Views)
Brian
Always be careful with file paths when calling external files from an executable. If your file paths are static make sure the directory they are pointing to is the same since the executable is likely in another folder than your development VI. You may try to make the paths relative to the runtime folder. While you are trying to debug this try setting the path to a front panel control so you can point to the dll at run time in the executable. Let me know if this helps.
Are you running the executable on the same development machine?
What Version of LV are you using
(3,611 Views)
Do you have any file operations?
One common culprit is, as Huter said, is file paths, and failure to heed errors from file-related functions.
How are you specifying the path to the DLL?
If you're on Vista, be aware that you cannot write a file in the same folder as your application (if you install in the usual PROGRAM FILES place).
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,595 Views)
Steve-
I do have file operations, but they are triggered by user input.  The crash happen right away, which coincides with the dll calls.  I only specify the dll path in the "Call Library Function" popup during development.  This is on an XP system.
Brian
(3,588 Views)
Just for grins, pop up a dialog just before the DLL call that says "CALLING DLL", and one right after, saying "BACK FROM DLL"
If you get one dialog, and then the crash, then you're right.
I meant what path are you specifying? is it absolute, or relative?
Steve Bird
Culverson.com
LinkedIn
(3,582 Views)
