Executable Application error
When I go to use my application for the first time I get an error message "The instruction at "0x3036653e" referenced memory at "0x65542f50" could not be read"
The first few front panels execute ok, then it comes to a certain front panel and the above message appears. When the exe closes, I run it again and the code works fine throughout.
Can anyone suggest how to put this right?
(2,767 Views)
This is not normal, so you have to tell us what is abnormal about the panel
that causes the problem.
Is there any hardware communication in there? .NET, ActiveX, dll's,
XControl, variants, LabVOOP classes? Do you use any properties or methods in
the VI?
Does the problem reproduce when you rebuild the executable? Also if you
change the problem vi a little and save it? You could try to save it to
previous version, and then reload it.
What version of LabVIEW are you using (and what OS)?
Wiebe.
(2,735 Views)
