Exe file should run after when we press the RUN button on Front Panel
I converted my vi file to .EXE file. Now when I open the .exe file It starts running automatically. I know using Event structure and one button I can execute manually. But I want to Run the program only when I press RUN button on front panel. If there is any way please let me know.
Thanks in advance.
Thanks & Regards
Saamy
(2,745 Views)
When you build an exe, in source file settings -> Click customize VI properties
and then under execution uncheck Run when opened, this should solve your problem
Aarthi
(2,738 Views)
Thanks a lot Aarthi, I will try to do that & let u know if it works..:)
Thanks & Regards
Saamy
(2,733 Views)
Simple but good.. Till now I have never tried to do that and I do not know that option is available. Learnt a new thing today.
(2,726 Views)
