Exe file Regarding
I have created an application using DAQ 6009,Now i have created an exe file but whenever i try to run the exe file in another system in which Labview is not installed im getting error that Resources Not Found..
 I have installed the following in the system(Runtime engine 2010 and ni-daq Daq Acquistion Software)
(2,877 Views)
Make sure that the device name(s) you are trying to access (i.e. the USB-6009) is named identically on the developmement machine and on the deployed machine where you are running the executable.
If you still have problems, please post your code.
Dan
(2,857 Views)
I Have attached my exe file with this reply..
(2,841 Views)
hello sir
           I tried it again by reinstalling those software and driver package, now it is opened without error.. thank you
(2,835 Views)
