Exclude unwanted items from build exe properties of .lvproj
Hello All,
I'm trying to exclude few items (VIs, lvtest etc) from build exe properties.
I cannot remove these VIs and lvtest from .lvproj, because they should be part of the class, as I want to test private VIs using "Unit Test Framework".
I have to exclude the "Unit Test Framework" files from Build properties because its presence will lead to adding VIs in exe which will increase exe size and that doesn't have any significance in exe.
Please help me.
(2,649 Views)
Maybe you can use a conditional compilation symbol to exclude UTF vi calls in the production build.
Paolo
(2,643 Views)
@pincpanter
Thanks for the response.
UTF VIs are not SubVIs. Is it possible to disregard top-level VIs from Build Specs using Conditional symbol?
Smiley Indifferent
(2,611 Views)
Sorry, it was a wild guess. I never really used UTF.
AFAIK, it's not possible to exploit conditional symbols in Build Specs.
Paolo
(2,606 Views)
