Exception in Call Library - Execution Trace Toolkit
I installed the Execution Trace Toolkit 1.0 on my LV 8.2 (with no prior LV installation). However, all examples had a broken arrow, and the Trace Tool gave lots of warning when started.
I tried the operations listed here: [broken link removed; article no longer available]
(The first 4)
I have LV 8.2 and not 7.1, but I did not find anything else that could fix the problem:
I know get no Errors when Opening the Execution Trace Tool, and examples have no broken Run Arrows (like they did before). However, trying to run e.g. the example  below, I know get this new error as you can see below: (All examples give the same error:)
Execution Trace Tool is started before trying to rung the example
What is the solution to this problem ?
Geir Ove
Message 1 of 1
(2,649 Views)
