Excelproblem
Hello there,
I have a problem with saving data into an excelsheet. It worked before 100%
When you´re looking in my vi you wil see how it works, only with timer 1 i´ve changed it and the rest is still original.
What went or going wrong here.
Tia, William
I´m running with: Labview 6.1
Running with Labview 6.1
Fieldpoint hardware
(2,975 Views)
Try making the timer VI reentrant. It looks like you are wanting to have it be two seperate timer operations but the internal uninitialized shift register links them because the value after the last execution is still there when the next one begins.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,966 Views)
