Excell via ODBC
I have ported a aloder LV project from a Win3.11 engine
to a Win NT4
This project accesses .xls data via ODBC
Question : in ODBC access setting, folder "User DNS"
you must select a Workbook ( a *.xls file )
This means it accesses only this named file.
How to make ODBC access any in LV specified file without
reconfiguring the ODBC Data Sources ?
Or can LV rename a *.xls to a given constant name ? this would
solve my problem too
Jean-Luc
(2,695 Views)
Maybe this helps, allthough it's no exact awnser to your question (I
think..).
You can create, modify and read the ODBC sources through the registry:
for user dsn:
HKEY_LOCAL_MACHINE/SOFTWARE/ODBC/
All the available drivers are in ODBCINST.INI, all sources are in ODBC.INI.
You could modify a ODBC NSD's source file to point to the desired file.
Use regedit to debug.
Hope it helps,
Wiebe.
"Jean-Luc" wrote in message
news:3c56de68$0$4607$626a54ce@news.free.fr...
> Hi,
> to a Win NT4
> How t
> Thanks
> Jean-Luc
(2,695 Views)
