Excel
hello Dennis,
I got it running. Only thing is it saves values in a "row" in the Spreadsheet File.  I wasnt it to save them in one column. Is that possible?
Thank you!
Message 21 of 36
(1,803 Views)
I have it already opning in the Excel. So is it possible to switch to one COLUMN instead of the row?
Also, I cant find PNG file that you showed me!
Message 22 of 36
(1,795 Views)
What is the file extension you are using for the file that is being created? Is it xls or csv? If you want to use either of these extensions, then you should change the delimiter to a comma. The default is a tab. When select a file extension of .txt for example, I tell Excel to open the file and I explicity select tab as the delimiter.
Message 23 of 36
(1,786 Views)
I cant get ONE COLUMN and then differnt rows.
This i swhat Im getting. I want the whole thing in one column! is there a way to use "ENTER" command?
Thank yoU!
Message 24 of 36
(1,779 Views)
Before you use Excel to open the File, look at it with Notepad. You also didn't answer me about the file extension. Change it to txt and post it and I will look at it.
Message 25 of 36
(1,776 Views)
Here it is...With .txt extension!
Message 26 of 36
(1,774 Views)
I meant the actual file - not an image.
Message 27 of 36
(1,770 Views)
Message 28 of 36
(1,767 Views)
No, no no. The actual data file that is being created by the Export Waveforms to file. The one you seem to have problems with reading with Excel.
Message 29 of 36
(1,764 Views)
It looks like Im missing something.
These are the files that Im aware of!
Message 30 of 36
(1,764 Views)
