Excel
I want to write data from a table/array to a specific sheet of an excel file..can u please suggest an example VI related to that..Or could you please explain me how can i achieve that..??
Thank you.
Thanking you,
Sushmith
(3,216 Views)
Hi Sushmith,
Using Report Generation toolkit you can do that very easily.
Below is vi with which you can write data to specific sheet in excel.
Bijay
(3,208 Views)
Hi sushmith,
                   It is very simple.Go to the block diagram of Write to Spreadsheet File. There are directions there on what to do to make the VI accept arrays/table of strings.
Also go through this link:-
http://forums.ni.com/t5/LabVIEW/How-can-i-save-data-in-Excel/td-p/191982
Thanks as kudos only:)
(3,206 Views)
Hi Danil,
Good you are helping us but first read the Ques carefully and then reply for the same.
Bijay
(3,199 Views)
