Excel spreadsheet as input to PID Setpoint Profile VI
Sure!
This is an Excel ".csv" file (comma delimited) with 2 columns:
Time (seconds) and randomly generated setpoints (mmH2O in our case ).
Message 11 of 27
(1,624 Views)
bmann2000,
No, I have not. But will try.
Thanks for your reply!
Message 12 of 27
(1,623 Views)
Hi Perillo_U...,
the attached example should work for you.
If not, can you upload you vi?
Mike
Message 13 of 27
(1,612 Views)
Hello Mike,
No, I am having the same problem and attached the VI for you.
Thanks Mike!
Message 14 of 27
(1,606 Views)
Hello bmann2000,
The problem really isn't reading the data, but reading in an appropriate fashion to make it match the structure needed to feed the PID Setpint Profile SubVI.
Message 15 of 27
(1,587 Views)
To help clarify, I am posting a copy of the PID Setpoint Profile VI.  Maybe this will help some.
Thanks!
Message 16 of 27
(1,552 Views)
Hi Perillo,
I took a look at your VI and it looks like you are inputting the correct data type.  What type of error are you getting?
Justin P
Justin Parker
Product Support Engineer
Message 17 of 27
(1,539 Views)
Hello Justin, thanks for your interest.
Well,  apparently it reads all data from spreadsheet at once instead of sequentially, so a few seconds later I got either a "zero" value or "NaN".  This VI is actually a SubVI used in a control VI.
Message 18 of 27
(1,532 Views)
Does the second Setpoint Profile VI with the constant wired into it read the values sequentially?
Justin
Justin Parker
Message 19 of 27
(1,521 Views)
The second VI is just a copy from the original included in LabView installation package (Real time package), which not everyone has access to, but when I try to substitute the constant with the data from the spreadsheets it gets messed up.
Message 20 of 27
(1,517 Views)
