Excel open
when opening Excel template from within LabVIEW and the customer closes
Excel accidentally outside LV will create big troubles. I've got a hint to
prevent closing Excel outside LV but never succeeded ordently with that. Has
anybody tried to use Excel macro to to do the thing. I'm not very used to
use Excel macros. Any good hints. I use LV 7.0-7.1 with Microsoft Report
Generation toolkit v.1.01.
Thanks Eki
(3,115 Views)
Hi Eki,
In response to your question, I do not believe macros will prevent a user from closing an Excel file. Macros are comparable to scripts that help automate a task that you may want to run repeatedly. To workaround your problem, you can have LabVIEW automatically reopen an Excel file if it has been closed outside of LabVIEW. Otherwise, if LabVIEW is generating any errors with the Excel file not open, you have incorporate error handling in your program and subsequently reopen Excel.
Hopefully this will give you some pointers to solving your issue. Good luck!
Kileen C.
(3,115 Views)
