07-22-2005 02:45 PM
07-22-2005 03:42 PM
07-26-2005 09:59 PM
07-27-2005 06:47 PM
07-27-2005 07:12 PM
07-28-2005 06:58 PM
I'm having the same error, and by all indications the analysis toolpak add-in is always installed and enabled.
It seems curious, though, that there are other instances of the DEC2HEX function being employed in the spreadsheet at i23 and i25, but they never result in a #NAME error. It only happens when LabVIEW accesses one of the cells indirectly involved in the calculation.
07-29-2005 08:38 AM
I think what is happening is the other two dec2hex conversions are not being recalculated. Excel is just showing the last saved value. If when you get the error go to the input cell that will change the other dec2hex conversion cell B20 and change the value slightly. That way excel will have to recalculate the dec2hex conversion. What you will see is that it will show the same error (#Name). It like the active X calls forgot one function, that is to recalculate using the addins.
Sorry it didn't work for you either. If you have any luck let me know. I will also keep looking.
08-01-2005 11:42 AM
08-30-2006 01:36 PM
08-30-2006 01:41 PM
