Excel insert Graph VI error
Hello everyone,
 I am trying to separate the report generation portion of a software that I am working on but I am experience an issue with the graph shapes node. Let me give you a quick history of the thing..   The software is working properly when it is in the original shape ( part of a big software that been outsourced). after I did separate the report generator portion of the software I was able to run and generate a full report for one time only then after that the VI runs OK until it come to the point of insert a graph. so the excel file created and all sheets were created correctly and when it get to the graph shapes node a message pop up saying excel stop working and the LabVIEW gives me this error " Error -2147023170 occurred at The remote procedure call failed.
 in NI_Excel.lvclass:Excel Insert Graph.vi->Create Excel Report.vi->Write Summary Sheets.vi->ReportZ.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-2147023170) or for its hexadecimal representation (0x800706BE).". I appreciate your time and consecrations.
Message 1 of 8
(5,182 Views)
According to this article, the issue occurs due to multiple ActiveX calls in quick succession and suggests leaving a 50ms delay between calls (ie. in your for loop).
http://digital.ni.com/public.nsf/allkb/666386AA5FCAD23086256CED00810C23?OpenDocument
Message 2 of 8
(5,163 Views)
Thank you. I
added this 50ms but still having the same issue
Message 3 of 8
(5,158 Views)
Message 4 of 8
(5,154 Views)
I can confirm that doing multiple calls to Excel-specific RGT functions can cause strange Error conditions that are cured with a brief delay following the function.  Two places I've used it is to place a 100 ms delay between Save Report to File and Dispose Report and an additional 500 ms delay after Dispose Report (when I'm processing multiple Workbooks in a For Loop).  I haven't done a test to find the "minimum value" for these delays -- in the context of the data processing, an "idle second" is no big deal compared to a crash for "no good reason", especially when someone else is running the program.
Message 5 of 8
(5,152 Views)
@McQuillan wrote:
Can you upload your code?
I do not think I can upload the hole codes.
Message 6 of 8
(5,144 Views)
Thank you, Can you please use my snip shoots and tell me where to add these delays? Please
Message 7 of 8
(5,143 Views)
I can do it if you show it to me.  I see a (tiny?) piece of code that has three functions on it, neither of which I would think would cause a problem.
Here's what you should do -- copy the VI that you are showing as a picture -- call it "My Example" or something.  Delete everything except anything that uses the Report Wire, then get rid of all the "blank" spaces.  You should end up with a few functions that start with New Report and possibly end with Dispose Report (I don't know how you end the Report).  Then attach this VI -- if you post a picture, I won't look at it, as it doesn't give me enough information to understand fully what you are trying to do.
Bob "No Pictures, Please" Schor
Message 8 of 8
(5,141 Views)
