Excel graph plot
Hi, i want to plot my test result with Excel, so i refer to the sample named Excel macro example.vi, but i realize that only 5 point can
be plotted on the chart, so anybody tell me how to plot all the point?
thanks
(3,100 Views)
You can indeed plot more than 5 points.  Post your VI and I wll take a look at it.  Excel works fine so it has to be your VI.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,086 Views)
The reason only 5 (actually 6) points are plotted is because the Excel macro ('GraphData' in project.xls) is doing the plotting and its script tells it what to plot.  If you select Tools>Macros in the project.xls workbook you can open the script and edit it.
Keep in mind LabVIEW is not plotting anything in Excel.  It is simply running a pre-existing excel macro.  If you need to plot in excel the easiest way is to use the chart wizard after you have moved your LabVIEW data to a spreadsheet.  Otherwise you'll have to learn to program macros in Microsofts Visual Basic.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,070 Views)
