Showing results forĀ
Search instead forĀ
Did you mean:Ā
Excel data Issue
Hello everyone, im having an issue with my excel document, my labview application  generates some values and i need to write those numbers in my excel document, but when i generate those numbers automatically my excel document only register Zeros, y tried everything i hope someone can help me
thanks 4 ur help! šŸ˜„
(1,792 Views)
Accepted by topic author JesusG2000
Yeah, simple the problem is in your code but we can't help because you did not share your code to see where you went wrong.
Santhosh
Soliton Technologies
(1,775 Views)
When you submit your code, we want to see "editable code", which means one or more LabVIEW VIs.  Since some of us are not (yet) running LabVIEW 2022 and later, please "Save for Previous Version" if you are running the most recent versions of LabVIEW (LabVIEW 2019 or 2021 should be fine for 95% of the Forum users, including everyone running LabVIEW 2023 ...).
(1,766 Views)
