Excel Spread Sheet Encryption
Hello All,
I have generated a .csv file with all the necessary information that I entered as a result of some task execution using the Writing Tab Delimited String to Delimited Spreadsheet. The .csv file is now saved in the location that I have directed it to. Works as expected.
Now I am looking to generate an encrypted spreadsheet that should be "read only" or "password protected sheet" using the Write Delimited Spreadsheet.vi. Looking forward for your responds.
Thank you in advance.
(2,902 Views)
A couple things.
Write Delimited Spreadsheet does not create an Excel Spreadsheet file.  It creates a text file.  If you name it as a .csv, then Excel is able to import that file when it opens it, but it is still not an Excel file.
So any encrypted/password functions that Excel has won't apply to it.
(2,840 Views)
What are you hoping for with your result? Do you want a file that one authorized people can open and read? Do you need it to only open in Excel? You could use a zip file with a password to do what you are looking to do. You could write a binary file and give the other person a reader (you would have to build this). You could go a step further and write encrypted data. then save it to a binary file. You would again need a reader that would decode the encryption and format back to data that you want. There was a LabVIEW version of a program for encryption called Blowfish. I am not sure if it is still available or not.
Tim
GHSP
(2,834 Views)
