Excel Report
Hello.  I have 3 VIs which make 3 excel reports. They work independently. I would like to know if I can write the 3 reports in only one Excel file (in separated sheets). I have try it but when I save the file, Labview overwrite the 3 sheets, not only the sheet where I generate the report.
Thank you.
(4,379 Views)
Have a look at the excel board in the breakpoint area. There are some vi's in there that will help you. You have to set the active workbook and then save it.
Joe.
"NOTHING IS EVER EASY"
(4,369 Views)
The attached example may help.
Scott.
(4,369 Views)
This will only work if you have the addon toolkit, the vi's in the other thread do not require the toolkit, they all use active X.
Joe.
(4,368 Views)
Thanks for repply!!
I have the toolkit, but I want is: open VI1-save report in worksheet1-closeVI1, open VI2-save report in worksheet2-closeVI2, open VI3-save report in worksheet3-closeVI3.  I have seen the activeX VIs, but I can't find one which solve my problem.
(4,362 Views)
if you connect the Excel file path to template input parameter of New Report.vi, you will be able to obtain what you want.
I hope this helps.
crisR
(4,284 Views)
Thanks for reply!
It seems a good solution.
(4,250 Views)
