Excel Graph Legend Formatting - Report Generation Tool
Hi all,
I'm currently using the Report Generation Tool for Labview '11 and cannot seem to figure out how to edit the font properties for a graph's legend. Attached is a screenshot of an example output.
The Excel Graph Font.vi's Help file says that it should be able to modify the legend, yet I can't seem to figure out how to configure it to do so. If anyone can walk me through the steps or tell me what I am missing, I'd greatly appreciate it.
Message 1 of 9
(5,750 Views)
It's hard to say without seeing the code but to format the font use the Excel Set Graph Font vi after adding the graph. This vi apply to the last graph you've inserted. Refer to the LV help for this vi for more details.
Ben64
Message 2 of 9
(5,747 Views)
I used that VI for formatting the X and Y axes, but can't get it to format the legend... I've referred to the help that says it can format the legend, but doesn't really give instruction on how to.
I've attached a snippet of the VI after the Append Table to Report.vi.
Message 3 of 9
(5,729 Views)
OK I found a (not trivial) way to modify the graph legend. See the attached vi.
Ben64
Message 4 of 9
(5,706 Views)
Nice, Ben64. This is a great example for the Code Exchange!
http://www.ni.com/code/
Ravi A.
National Instruments | Applications Engineer
Message 5 of 9
(5,702 Views)
Accepted by topic author ChaoyD
Added minor corrections (deleted end of line characters from row and column headers).
Ben64
Message 6 of 9
(5,698 Views)
Thank you for the vi, ben64; it worked great! I modified it to accept a report in, as I'd like it to be more modular, but the ActiveX stuff was spot on and does exactly what needed to be done.
Message 7 of 9
(5,692 Views)
Hello again,
It seems my team has decided to change direction and use Word instead of Excel. As such, I've been attempting to convert the VI ben64 provided, but I'm stuck on the ActiveX references... I've attached what I've done so far, but could someone help me (or instruct me) on making this VI work with Word?
Thanks.
Message 8 of 9
(5,665 Views)
@ChaoyD wrote:
Hello again,
Thanks.
The Word object model is probably the most complicated of the Office suite and you are loosing the calculation ability of Excel.
 Attached is a vi to format the chart legend in a Word document.
Ben64
Message 9 of 9
(5,658 Views)
