Excel Column values to array
Hi , I need to store the values of an excel column in a string array, how can I do this?
Message 1 of 11
(3,979 Views)
Hi falafes,
read the Excel worksheet (using RGT functions) and get column C as a string array…
Message 2 of 11
(3,972 Views)
I don't seem to have that function
Message 3 of 11
(3,958 Views)
Hi falafes,
So what do you have available?
Which LabVIEW version, which bitness, which toolkits?
Did you install the RGT (Report Generation Toolkit)?
You might even use "simple" ActiveX nodes to communicate/remotely control Excel!
Message 4 of 11
(3,951 Views)
I'm on 32 bit LV2017, I don't have RTG I just checked but it says that's for google sheets, will it still work on excel?
Message 5 of 11
(3,936 Views)
I have never heard of it associated with Google.  (Maybe it can handle that too.)
But it RGT = Report Generation Toolkit is definitely for Excel
Message 6 of 11
(3,927 Views)
Okay I installed RGT but I still don't know which VI to use?
Message 7 of 11
(3,891 Views)
Hi falafes,
when you installed the RGToolkit then you have its example VIs available in the example finder.
Did you explore them to learn how to use the RGT functions?
Message 8 of 11
(3,886 Views)
Okay this is what i have so far, but how do i put this in an array??
Message 9 of 11
(3,880 Views)
Hi falafes,
Whatever that is it is not from RGT as supplied by NI.
Where do you got this VI from?
Message 10 of 11
(3,876 Views)
