Excecutable VI generating an error 222 on Keithley 2612A although its run properly when starting from labview 2009 directly
Dear all,
I have a VI which runs perfectly and I can control, a Keithley 2612A for transistor measurements.
The VI run well when I excecute it from the computer which has the platform Labview 2009 (XP OS)
The equipment (ie Keithley 2612A) is linked to another computer which don't have labview 2009.
I installed Run-time-engine 2009 (OS XP 32 bits) on this computer.
Then I create an excecutable of my VI with the "build application" option.
The excecutable VI starts normally on the computer but when I want to run it, I am getting an error message from the Keithley 2612A (which was not the case when I ran the VI directly from the computer haing Labview 2009 installed on it). The error message is 222 (ie parameter too long)
I thought that I did something wrong and I create an excecutable from an original VI from Keithley (ie without any change). I am getting the same error message.
When I create an excecutable with run time engine 2009 included (as it is possible to do it wiht LB 2009) , I am geeting the same error message.
So I need no to check step after step when the message happens  but
Does anyone knows anything about such an issue ?
Thank you
(4,040 Views)
Accepted by topic author Youki
Dear all,
Just for those who might encounter a similar issue.
I found the solution after tackling all possibilities.
The source of the problem was (for unknown reason) that the country setting of the computer was wrong
and decimal numbers were written with a , instead of a point.
Since I reset correctly the country setting, the stand alone files are running normally.
Best regards
Youki
(4,015 Views)
