Example study problems for Labview
I've found 3 sample Labview study problems, on the NI website, that are intended to be used as practice tests for the CLD. These posts were the Traffic Light Controller, the Security System and the Car Wash problems.
Does anybody know of an area where I can find more LV example problems to practice with that are similiar in scope to these problems?
(4,662 Views)
Hi
I am also preparing to CLD, and I found only tree examples just like you.
I thing if you be lucky you will find somethink else ...
bogdani
(4,627 Views)
I thought I would point out that National Instruments does offer an online CLD Exam Preparation Course.
You might be interested in checking that out!
Kind Regards,
E. Sulzer
(4,600 Views)
If you can solve the example exams that they provide in the 4 hour limit then you have a good chance of passing.  This means lock yourself in a room, start from scratch, and code for 4 hours straight and see what you have at the end of 4 hours.  It is not the same as programming 1 hour a day for four days.  Keep in mind that you need to read and follow the LabVIEW style guide to the best of your ability.  As it states on the sample exams:
Programming style (15 points)
Functionality (15 points)
Documentation (10 points)
This means that you get 15 points (37.5%) to make it work.  If you don't do the documentation or have good programming style you will fail.  Based on my personal experience if you have less than two years of solid LabVIEW then the prep course would be a good choice.  This assumes that you have good programming style and use all that is recommended in the exam and LabVIEW style guide.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,585 Views)
Hi
You ofcourse can read as many as possible of this CLD examination.
Also on this page: https://www.ni.com/en/shop/services/education-services/certification-program.html you will find meny information about NI Certification program, but I think you already know the page.
bogdani
Message Edited by Support on 05-29-2007 03:14 PM
(4,575 Views)
